Linked Objects and Binder
I have a question. I need find out all linked documents in a solid edge document in unsaved state. Because of this I can not use RevisionManager( It is only for saved documents)
There is a possibility to find occurrences in assembly and also part copy in parts, but I nowhere found objects from “Binder” (see Edit->Binder)
By UI it is possible to see it in the dialog Edit->Links and also Edit->Binder, but by API?
As I wrote I need this for unsaved document…
For me it is confused, why I can see this by UI but I can not see it by API.
Thank for any response.
Petr
Posted by: Petr Bartoš
Post date: 9/13/2007 2:30:05 AM
RE: Linked Objects and Binder
Petr,
It is not available via the SE API (to my knowledge).
Posted by: Jason Newell
Post date: 9/18/2007 1:28:59 PM
