LocateFilter combinations to get a point
Hello everybody,
I try to locate different points. (2d-points, vertex, start-, middle- and endpoints of 2D+3D lines)
I have problems with the correct combination of the locate filter. I use the SE AddIn from Jason Newell and SolidEdge V 20.
I have changed the command.h file:
    //ISEMousePtr    m_pSEMouse; // from Jason Newell
    ISEMouseExPtr    m_pSEMouse; // new - to get access to the method PointOnGraphic
Is there a reason, that the ISEMouseExPtr is not used generally (i.e. problems with PointOnGraphic method)?
The following filter settings are used in the activate method:
        m_pSEMouse->ClearLocateFilter();
        m_pSEMouse->AddToLocateFilter( SolidEdgeConstants::seLocatePoint2d );
        m_pSEMouse->AddToLocateFilter( SolidEdgeConstants::seLocateVertex );
        m_pSEMouse->AddToLocateFilter( SolidEdgeConstants::seLocateKeyPoint );
When I use the filterconstant seLocatePoint2d and seLocateKeyPoint in combination the 2d-points aren´t fetched.
How can I even fetch the 2d-points correctly ?
When I use the seLocateKeyPoint filter the keypoints get highlighted by a small red circle.
After selection this circle is still visible. Is there a way to remove this circles ?
The realy strange thing is, that when I display a message box before the m_pSECommand->Done = VARIANT_TRUE; - call, the circle is removed.
What´s the difference between seLocateVertex and the seLocatePoint Filter?
Has anybody found some useful combinations to locate points ?
Thanks in advance
Matthias
Posted by: Matthias Senff
Post date: 10/20/2008 2:20:18 AM
