LoftedProtusion
Hello guys,
I am trying to develop a Lofted Solid with a degree of rotation (Like the picture).
I have got the Solid without rotation, but when I try to rotate the second sketch and perform the Lofted-Protusion, the feature does not work.
I am not sure if the points "Origins" that have to be defined on the Add.LoftedProtusion are corrected defined in my code.
Does anybody please could be so kind to help me?
Dim X1 As Double = -0.05
        Dim Y1 As Double = 0 - 0.05
        Dim X2 As Double = 0.05
        Dim Y2 As Double = -0.05
        Dim X3 As Double = 0.05
        Dim Y3 As Double = 0.05
        Dim X4 As Double = -0.05
        Dim Y4 As Double = 0.05
        ' Get a reference to the documents collection
        objDoc = objApp.Documents
        ' Create a new part document
        objPart = objDoc.Add("SolidEdge.partDocument")
        ' Get a reference to the sketches collection
        collSketches = objPart.Sketches
        ' Add a new sketch
        objSketch = collSketches.Add()
        ' Get a reference to the profiles collection
        collProfiles = objSketch.Profiles ' objProfileSet.Profiles
        ' Get a reference to the ref planes collection
        collRefplanes = objPart.RefPlanes
        ' Add a new profile
        objProfile1 = collProfiles.Add(collRefplanes.Item(3))
        ' Get a reference to the lines2d collection
        collLines2d = objProfile1.Lines2d
        collPoints2d = objProfile1.Points2d
        objLine2d = collLines2d.AddBy2Points(X1, Y1, X2, Y2)
        objPoint2d = collPoints2d.Add(X1, Y1)
        objLine2d = collLines2d.AddBy2Points(X2, Y2, X3, Y3)
        objLine2d = collLines2d.AddBy2Points(X3, Y3, X4, Y4)
        objLine2d = collLines2d.AddBy2Points(X4, Y4, X1, Y1)
        'Define Relations among the Line objects to make the Profile closed
        collRelations2d = objProfile1.Relations2d
        objRelation2d = collRelations2d.AddKeypoint(
        collLines2d.Item(1),
        SolidEdgeConstants.KeypointIndexConstants.igLineEnd,
        collLines2d.Item(2),
        SolidEdgeConstants.KeypointIndexConstants.igLineStart)
        collLines2d.Item(3),
        collLines2d.Item(4),
        ' Close the profile
        objProfile1.End(SolidEdgePart.ProfileValidationType.igProfileClosed)
        ' Show the profile
        objProfile1.Visible = True
        'Add a new sketch
        ' Add a new reference plane
        objRefplane5 = collRefplanes.AddParallelByDistance(collRefplanes.Item(3), 0.25, SolidEdgePart.ReferenceElementConstants.igNormalSide, , , False)
        ' Add a new profile
        objProfile2 = collProfiles.Add(objRefplane5)
        collLines2d = objProfile2.Lines2d
        ' Draw the Profile
        Dim X1_2 As Double = 0
        Dim Y1_2 As Double = 0
        Dim X2_2 As Double = Sqrt(2) / 20
        Dim Y2_2 As Double = Sqrt(2) / 20
        Dim X3_2 As Double = 0
        Dim Y3_2 As Double = 0.1414213564
        Dim X4_2 As Double = -Sqrt(2) / 20
        Dim Y4_2 As Double = Sqrt(2) / 20
        'Dim X1_2 As Double = 0
        'Dim Y1_2 As Double = 0
        'Dim X2_2 As Double = 0.1
        'Dim Y2_2 As Double = 0
        'Dim X3_2 As Double = 0.1
        'Dim Y3_2 As Double = 0.1
        'Dim X4_2 As Double = 0
        'Dim Y4_2 As Double = 0.1
        objLine2d = collLines2d.AddBy2Points(X1_2, Y1_2, X2_2, Y2_2)
        objPoint2d_2 = collPoints2d.Add(X1_2, Y1_2)
        objLine2d = collLines2d.AddBy2Points(X2_2, Y2_2, X3_2, Y3_2)
        objLine2d = collLines2d.AddBy2Points(X3_2, Y3_2, X4_2, Y4_2)
        objLine2d = collLines2d.AddBy2Points(X4_2, Y4_2, X1_2, Y1_2)
        ' Define Relations among the Line objects to make the Profile closed
        collRelations2d = objProfile2.Relations2d
        SolidEdgeConstants.KeypointIndexConstants.igLineEnd, _
        objProfile2.End(SolidEdgePart.ProfileValidationType.igProfileClosed)
        ' Show the profile
        objProfile2.Visible = True
        ' Get a reference to the models collection
        collModels = objPart.Models
        ' Create the lofted protrusion.
        dblOrigin(0) = X1
        dblOrigin(1) = Y1
        objOrigins(0) = objPoint2d
        dblOrigin(0) = X1_2
        dblOrigin(1) = Y1_2
        objOrigins(1) = objPoint2d_2
        objCSArray(0) = objProfile1
        objCSArray(1) = objProfile2
        lngCSTypeArray(0) = SolidEdgePart.FeaturePropertyConstants.igProfileBasedCrossSection
        lngCSTypeArray(1) = SolidEdgePart.FeaturePropertyConstants.igProfileBasedCrossSection
        objModel = collModels.AddLoftedProtrusion(
            NumSections:=2,
            CrossSections:=objCSArray,
            CrossSectionTypes:=lngCSTypeArray,
            Origins:=objOrigins,
            SegmentMaps:=0,
            MaterialSide:=SolidEdgePart.FeaturePropertyConstants.igLeft,
            StartExtentType:=SolidEdgePart.FeaturePropertyConstants.igNone,
            StartExtentDistance:=0,
            StartSurfaceOrRefPlane:=Nothing,
            EndExtentType:=SolidEdgePart.FeaturePropertyConstants.igNone,
            EndExtentDistance:=0,
            EndSurfaceOrRefPlane:=Nothing,
            StartTangentType:=SolidEdgePart.FeaturePropertyConstants.igNone,
            StartTangentMagnitude:=0,
            EndTangentType:=SolidEdgePart.FeaturePropertyConstants.igNone,
            EndTangentMagnitude:=0)
Re: LoftedProtusion
Indeed, you have incorrectly defined your origins.
You don't need to create an additional point for the origins on the sketch, but can simply define the Origins argument (based on the profile coordinates) in the following way. That should give you a valid feature.
    Dim dblOrigin1() = New Double() {X1, Y1}
    Dim dblOrigin2() = New Double() {X1_2, Y1_2}
    Dim objOrigins() = New Object() {dblOrigin1.Clone(), dblOrigin2.Clone()}
Re: LoftedProtusion
Thank you very much, I have solved the proble.
