Macro utility working fine in Solid Edge v19 but Not working fine in ST3 - please help me :-(
I have created on custom macro program(CustomReport.exe) using VB.net and it is working fine in solid edge V19 but is not working with Solid edge ST3.
I have Changes the refrences(now linking to "C:\Program Files\Solid Edge ST3\Program" ) in vb.net solution and Compiled whole solution but still custom macro program is not working in ST3.
Do I missing anything to make my program work with ST3?
Please help me guys :-(
Posted by: K Chaudhari
Post date: 8/24/2011 7:46:47 PM
RE: Macro utility working fine in Solid Edge v19 but Not working fine in ST3 - please help me :-(
try some of the advice at this discussion
http://www.jasonnewell.net/Community/Forums/tabid/55/aft/4533/Default.aspx#4769
check your macro references, and see also if sync namespaces (i.e. SolidEdgePartSync,etc) are correct.
Posted by: alon raviv
Post date: 8/24/2011 9:31:56 PM
