Make Parts visible in Assembly.....?
Hi Jason,
i think i am disturbing you almost daily. But i have a problem regarding parts in assembly. i have a assembly, in that parts are hide. i want open that asm and make the parts visible(hide). i tried following code but it is not working. please take a look at it and suggest me the solution
Dim oSEApp As SolidEdgeFramework.Application
Dim oSEAsm As SolidEdgeAssembly.AssemblyDocument
Dim objOccs As SolidEdgeAssembly.Occurrences
Dim objOcc As SolidEdgeAssembly.Occurrence
Dim i as Integer
oSEAsm = oSEApp.Documents.Open(asm_path)
oSEAsm = oSEApp.ActiveDocument
oSEAsm.SaveAs(savepath & "\" & "1212.asm")
objOccs = oSEAsm.Occurrences
     For i = 1 To objOccs.Count
         objOcc = objOccs.Item(i)
         objOcc.Visible = True
     Next
oSEAsm.UpdateDocument()
oSEAsm.Save()
oSEAsm.Close()
Thanks in advance
Prasad Pawar
(Design Automation Engineer)
Posted by: Prasad Pawar
Post date: 9/28/2007 12:56:10 AM
RE: Make Parts visible in Assembly.....?
You didn't mention what part was not working, but I noticed the below:
Try removing the line:
objOcc = objOccs.item(i)
and change "objOcc.Visible = True" to "objOccs(i).Visible = True"
- Bill
Posted by: Bill Ledbetter
Post date: 9/28/2007 4:35:25 AM
Hi Bill,
Thanks for your reply but it is still not working I have attached jpg file so that you will get clear idae.
Thanks again
Post date: 9/28/2007 5:56:07 PM
Can you please post your entire code segment, because from what you have in your initial post, you are not even connecting to an instance of Solid Edge. Is this a sub-routine in a bigger program? If so, at what line of code is it failing? I had only looked at your For loop.
Post date: 9/29/2007 3:52:36 AM
Hi Bill,
Yes,it is a sub-routine of a program. The code is working fine without any error but nothing get revealed in the assembly. parts still remain hide.:-(
Post date: 9/30/2007 5:42:56 PM
I'm not sure what to tell you. The following code below works for me in V20:
Option Explicit
Public objApp As SolidEdgeFramework.Application
Public i As Integer
Sub Main()
Set objApp = GetObject(, "SolidEdge.Application")
With objApp.ActiveDocument.Occurrences
For i = 1 To .Count
.Item(i).Visible = True
Next
End With
End Sub
Post date: 10/1/2007 1:54:47 AM
