Material, Units, Templates, and Style Management
I tried changing the templates using the Application.SetGlobalParameter(SolidEdgeFramework.ApplicationGlobalConstants Parameter, Object Value) function.
It's possible to change the settings and I can see them in the options:
But they're not selected in the template list:
Sry that the screenshots are in german. You can get to this menu by entering the new menu and the click on "edit list":
Is it possible to change this option using the Solid Edge Api?
Thanks in advance,
loginator
Re: Material, Units, Templates, and Style Management
Hi loginator,
I don't think that this is possible. The selected list is saved in the users registry hive and will be restored when SE is started again.
I fear that changing the registry while SE is running will not change the dialog. But I did not not test this option.
JB
SE ST10
