Member of GetUserPhysicalProperties for PartDocument can not be found
I've writting the following code to retrieve a user entered (custom) mass;
        Dim objapp As SolidEdgeFramework.Application
        Dim objdoc As SolidEdgeFramework.SolidEdgeDocument
        objapp = Marshal.GetActiveObject("SolidEdge.Application")
        objdoc = objapp.ActiveDocument
        Dim volume As Double = 0
        Dim area As Double = 0
        Dim mass As Double = 0
        Dim centerofgravity As Array = Array.CreateInstance(GetType(Double), 3)
        Dim centerofvolume As Array = Array.CreateInstance(GetType(Double), 3)
        Dim globalInertia As Array = Array.CreateInstance(GetType(Double), 6) ' Ixx, Iyy, Izz, Ixy, Ixz and Iyz
        Dim principalInertia As Array = Array.CreateInstance(GetType(Double), 3) ' Ixx, Iyy and Izz
        Dim axes As Array = Array.CreateInstance(GetType(Double), 9) ' 3 axes x 3 coords
        Dim radio As Array = Array.CreateInstance(GetType(Double), 9) ' 3 axes x 3 coords
        objdoc.GetUserPhysicalProperties(Volume:=volume, Area:=area, Mass:=mass, CenterOfGravity:=centerofgravity, CenterOfVolume:=centerofvolume, GlobalMomentsOfInteria:=globalInertia, PrincipalMomentsOfInteria:=principalInertia, PrincipalAxes:=axes, RadiiOfGyration:=radio)
        MsgBox(mass)
 I keep on getting this error: "The public member of GetUserPhysicalProperties for type PartDocument can not be found." (hopefully I translated it right)
I am testing it on a part and according to the help file it is a member of PartDocument
 - Solid Edge Part Type Library > PartDocument Object : GetUserPhysicalProperties Method
Maarten Elings | Engineer
5 REPLIES 5
Re: Member of GetUserPhysicalProperties for PartDocument can not be found
Hi MaartenEl,
You have to define objdoc as SolidEdgePart.PartDocument instead of SolidEdgeFramework.SolidEdgeDocument.
Or maybe you can Trycast objdoc as SolidEdgePart.PartDocument and if not is nothing call the GetUserPhysicalProperties Method:
If Not IsNothing(TryCast(objdoc, SolidEdgePart.PartDocument)) then
objdoc.GetUserPhysicalProperties(Volume:=volume, Area:=area, Mass:=mass, CenterOfGravity:=centerofgravity, CenterOfVolume:=centerofvolume, GlobalMomentsOfInteria:=globalInertia, PrincipalMomentsOfInteria:=principalInertia, PrincipalAxes:=axes, RadiiOfGyration:=radio) MsgBox(mass)
End if
Hope it helps.
Héctor Pelayo Izquierdo
Engineering Department, JAE Ingeniería y Desarrollos, S.L.
Solid Edge ST9 MP5 | NX 9
Development: VB.NET
Thank you for your reply.
However both (see below) cause an unhandled exception:
unhandled exception has occurred in your application.
the parameter is incorrect exception from HRESULT: 0x80070057 (E_INVALIDARG))
        Dim objDoc As SolidEdgePart.PartDocument
        MsgBox(mass)
 and
        If Not IsNothing(TryCast(objDoc, SolidEdgePart.PartDocument)) Then
            objDoc.GetUserPhysicalProperties(Volume:=volume, Area:=area, Mass:=mass, CenterOfGravity:=centerofgravity, CenterOfVolume:=centerofvolume, GlobalMomentsOfInteria:=globalInertia, PrincipalMomentsOfInteria:=principalInertia, PrincipalAxes:=axes, RadiiOfGyration:=radio)
            MsgBox(mass)
        End If
It works for me.
Please revise your spell.
should be GlobalMomentsOfInertia:=
should be PrincipalMomentsOfInertia:=
Development: VB.NET
If user defined Area and user defined Volume are equals to 0 it throws an exception, so you have to define them.
Development: VB.NET
Thanks that solved it!
Apperently an event that was triggert before this GetUserPhysicalProperties event cleared the area and volume data
