Menu gone lost
I've followed the steps in http://www.jasonnewell.net/Community/Forums/tabid/55/aft/163/Default.aspx
When Solid Edge starts I can see my menu but when I'm opening a file it's lost - what am I missing?
my C#:
using Microsoft.Win32;
using System;
using System.Reflection;
using System.Runtime.InteropServices;
namespace MyAddIn
    [GuidAttribute("2A24FC8D-36EE-4967-BAA0-22E584B9149B"),
    ProgId("MyAddIn.Addin"),
    ComVisible(true)]
    public class AddIn : SolidEdgeFramework.ISolidEdgeAddIn
        private SolidEdgeFramework.AddIn m_addin;
        private SolidEdgeFramework.Application m_application;
        public AddIn()
        #region ISolidEdgeAddIn Members
        public void OnConnection(object Application, SolidEdgeFramework.SeConnectMode ConnectMode, SolidEdgeFramework.AddIn AddInInstance)
            // Store local variables for later use
            m_addin = AddInInstance;
            m_application = (SolidEdgeFramework.Application)Application;
            // Set Addin's GUI Version
            AddInInstance.GuiVersion = 1;
        public void OnConnectToEnvironment(string EnvCatID, object pEnvironmentDispatch, bool bFirstTime)
            try
                string[] commandNames = new string[3];
                commandNames[0] = "cmdAbout\n\nAbout System\nAbout";
                commandNames[1] = "cmdDuplicateFile\n\nDuplicate File\nDuplicate";
                commandNames[2] = "cmdTester\n\nTester \nDebug";
                int[] commandIDs = new int[3];
                commandIDs[0] = 101;
                commandIDs[1] = 102;
                commandIDs[2] = 103;
                m_addin.SetAddInInfo(Marshal.GetHINSTANCE(this.GetType().Module).ToInt32(), EnvCatID, "ManagedMenu", 1, 2, 1, 2, commandIDs.Length, commandNames, commandIDs);
                if (bFirstTime)
                    SolidEdgeFramework.Environment env = (SolidEdgeFramework.Environment)pEnvironmentDispatch;
                    env.CommandBars.Add("ManagedMenu",SolidEdgeFramework.SeBarPosition.seBarTop); //false, false);
                    m_addin.AddCommandBarButton(EnvCatID, "ManagedMenu", 101);
                    m_addin.AddCommandBarButton(EnvCatID, "ManagedMenu", 102);
                    m_addin.AddCommandBarButton(EnvCatID, "ManagedMenu", 103);
            catch (System.Exception ex)
                Console.WriteLine(ex.Message);
        public void OnDisconnection(SolidEdgeFramework.SeDisconnectMode DisconnectMode)
            if (m_addin != null)
                Marshal.ReleaseComObject(m_addin);
                m_addin = null;
            if (m_application != null)
                Marshal.ReleaseComObject(m_application);
                m_application = null;
        #endregion
        #region "Regasm.exe functions"
        // Called by Regasm.exe
        [ComRegisterFunctionAttribute()]
        static void RegisterServer(Type t)
            RegistryKey baseKey = null;
            RegistryKey summaryKey = null;
            AssemblyTitleAttribute titleAttribute = null;
            AssemblyDescriptionAttribute descriptionAttribute = null;
            try
                baseKey = Registry.ClassesRoot.CreateSubKey(
                @"CLSID\{" + t.GUID.ToString() + "}");
                if (baseKey != null)
                    // Tell Solid Edge to automatically load your addin
                    baseKey.SetValue("AutoConnect", 1);
                    // Write title
                    if (t.Assembly.IsDefined(typeof(AssemblyTitleAttribute), true))
                        titleAttribute = (AssemblyTitleAttribute)
                        AssemblyTitleAttribute.GetCustomAttribute(
                        t.Assembly, typeof(AssemblyTitleAttribute));
                        baseKey.SetValue("409", titleAttribute.Title);
                    // Write description
                    if (t.Assembly.IsDefined(typeof(AssemblyDescriptionAttribute), true))
                        descriptionAttribute = (AssemblyDescriptionAttribute)
                        AssemblyDescriptionAttribute.GetCustomAttribute(
                        t.Assembly, typeof(AssemblyDescriptionAttribute));
                        summaryKey = baseKey.CreateSubKey("Summary");
                        summaryKey.SetValue("409", descriptionAttribute.Description);
                    // Write required registry entries for a Solid Edge Addin
                    // See secatids.h in C:\Program Files\Solid Edge VXX\SDK\include
                    // CATID_SolidEdgeAddIn
                    baseKey.CreateSubKey(@"Implemented Categories\{26B1D2D1-2B03-11d2-B589-080036E8B802}");
                    // Specify the Environment Categories that you want you addin
                    // to work in
                    // CATID_SEApplication
                    baseKey.CreateSubKey(@"Environment Categories\{26618394-09D6-11d1-BA07-080036230602}");
                    // CATID_SEPart
                    baseKey.CreateSubKey(@"Environment Categories\{26618396-09D6-11d1-BA07-080036230602}");
            catch
            finally
                    baseKey.Close();
                    baseKey.Close();
        // Here we cleanup any registry values left from Regasm /u.
        [ComUnregisterFunctionAttribute()]
        static void UnregisterServer(Type t)
            try
                Registry.ClassesRoot.DeleteSubKeyTree(@"CLSID\{" + t.GUID.ToString() + "}");
            catch
        #endregion
Posted by: joseph polk
Post date: 1/18/2012 12:29:08 PM
RE: Menu gone lost
Well I had no idea bout the registry when posted this...
The code is fine for more environments add their appropriate string from the
\SDK\Include\secatids.h
and at the end of RegisterServer func:
baseKey.CreateSubKey(@"Environment Categories\{26618395-09D6-11d1-BA07-080036230602}"); // the CATID_SEAssemblys for Assemblies enviroment
Post date: 1/31/2012 11:36:16 AM
