Minimu distance
Hello all!
I would like to measure minimum distance in assembly from sketch reference plane
(in assembly) to face of one component
SolidEdgeAssembly.Layout layout =
(SolidEdgeAssembly.Layout)activeAssem.Layouts.Item(1);
SolidEdgePart.PartDocument partDoc =
(SolidEdgePart.PartDocument)
activeAssem.Occurrences.Item(1).PartDocument;
SolidEdgeGeometry.Body bodyObj =
(SolidEdgeGeometry.Body) partDoc.Models.Item(1).Body;
SolidEdgeGeometry.Faces faces = (SolidEdgeGeometry.Faces)
bodyObj.get_Faces( SolidEdgeGeometry.FeatureTopologyQueryTypeConstants.igQueryAll);
SolidEdgeGeometry.Face face =
(SolidEdgeGeometry.Face) faces.Item(1);
Array point1 = Array.CreateInstance(typeof(double), 0);
Array point2 = Array.CreateInstance(typeof(double), 0);
double distToCurrent;
activeAssem.MinimumDistance(layout.RefPlane,
face, out distToCurrent,
ref point1, ref point2);
but this function finishes with unknown error. Do you have any Idea what is wrong?
And second thing:
I am quite new in SolidEdge so sorry for stupid questions but I do not know what
is the difference between layout and sketch. As a second test i tried to copy layout
to component and measure minimum distance there (I checked that for two faces it
works) but when I succesfully copy layout to part than in partDoc is not member
"Layouts" but only "Sketches" and it does not have "RefPlane". How can I obtain
object of reference plane for sketches?
Jara
Posted by: Jara Ctverak
Post date: 4/23/2007 12:44:15 AM
RE: Minimu distance
I also try to use MinimumDistance from Circle to Face but I also get error from the face.
If I use MinimumDistance between 2 Circles, It works.
Did you found how to define the face and use it in MinimumDistance???
Please let me know.
Best Regards,
Amir Zeltzer
amir@mckit.co.il
Posted by: amir zeltzer
Post date: 9/8/2008 5:31:15 AM
