ModelLink. ChangeSource Method - how to use ?
hallo all
I try to use ChangeSource Method to change linked of .dft within .par.
idea is to create a model part and its draft
exam:
source: a model part and its draft, A.par; A.dft
copy these documents to another name, so that create new model part and its draft A1.par; A1.dft
                         a.par copy to a1.par;
                         a.dft copy to a1.dft
but the link of the new draft document is linked within the old model part document
                         a1.dft  link within a.par
i requirement :  a1.dft link to a1.par
but I dont kown how to chang this link
I'am new in visual Basic. can someone help me.
my code:
Private Sub CommandButton4_Click()
Dim ......
dftfile="D:a1.dft   'new draft
fullpath="D:\"
objname="a1.par"
On Error Resume Next
Set objApp = GetObject(, "SolidEdge.Application")
If Err Then
Err.Clear
Set objApp = CreateObject("SolidEdge.Application")
Set objDoc = objApp.Documents.Add("SolidEdge.DraftDocument")
objApp.Visible = True
Else
Set objDoc = objApp.ActiveDocument
End If
Call objDoc.Close
Set objDoc = objApp.Documents.Open(dftfile)                'open new draft document
Set objModelLink = objDoc.ModelLinks.Item(Index:=1)  'old model part is current link
Call objModelLink.ChangeSource(fullpath, objname)      'change linked document, the objModelLink.name=a.par
Set objApp = Nothing
Set objDoc = Nothing
Set objModelLink = Nothing
Set objModelLinkDocument = Nothing
end sub
Posted by: zhao cai
Post date: 2/26/2011 12:07:24 PM
RE: ModelLink. ChangeSource Method - how to use ?
You are using wrong arguments of the ChangeSource method. The first argument is the full file name (e.g. "D:\a1.par") and the second one is the name of member (in the case that link is FamilyOfParts).It can be empty.
Posted by: Tomas Vana
Post date: 3/2/2011 7:12:58 PM
