.NET Core or .NET Standard
Has anyone tried to automate Solid Edge using .NET Core or .NET Standard?
Terry Tyson
Software Automation Designer
Re: .NET Core or .NET Standard
Last time I checked, .NET Core does not support COM interop.
Jason Newell
Solutions Architect
www.jasonnewell.net
Hi Terry,
I've got no experience yet on my own, but I found following discussions and articles worth to be mentioned upon your question.
com interop with .net core 2.0
.NET core 3.0
I conclude it's currently better to stay with full .NET framework.
Kind regards,
Wolfgang Kunert - www.wksyspro.de
Thanks to everyone for the replys. Looks like it's still Framework for a while.
Terry Tyson
The consensus now across all .net developers is that Core is great if you have a new project, but not great for existing projects.  In this case, the Solid Edge .net api is an existing project and so it's best not to migrate.  Eventually Core will have most of the stuff in .net so it will be easier to move forward, but that's not yet here.
Alan Baljeu
Owner, Cornerstone Intelligent Software
Developer of custom CAD software
