Name of Blocks?
Hi every one.
I'm trying to make a macro to count and list the blocks used in a DFT file.
I got the count part working using Object.BlockOccurences.count
But I have no idea hot to get their names. Using BlockOccurences(i).name only lists:
BlockOccurrence 564
BlockOccurrence 828
BlockOccurrence 1705...
What I really need in the end is to list:
Block A was used x times
Block B was used y times
Blcok C ...
Any one has any idea how to access a block name?
Thank you!
Andz
Posted by: Anderson Baptista
Post date: 11/27/2006 12:48:04 AM
