Need help with addkeypoint to constrain a profile
Ok this one may be hard, but I need to add a keypoint between the line on top  and a random point on the center plane.  normally I would add a symetrical constraint but since the lines aren't equal lengths this won't work.  additionally, if I try to add a keypoint to the start, middle or end of the refplane I get a conflict with other constraints.  Anyone have an Idea of how I can fix this?
Bob Reinkemeyer
CAD Integration developer
Martin Sprocket and Gear Inc.
Re: Need help with addkeypoint to constrain a profile
Hi martyman,
As you did not say what you really try to do it is just guessing:
Use the AddVertcalAlign method to get the result in the second picture.
JB
SE ST10
That's exactly what I was trying to do, thank you so much!
Bob Reinkemeyer
