Need one sample VB Programme for the attached sketch part file ?
Hi there Jason,
                               I have drawn one sketch in part file, for tube. If you can help me out to write a programmer
for the same sketch. so that i can know more about the simple sketch Prog. Using VB only.
Hi Shakib01,   The help file for SDK (C:\Program Files\So...
Hi Shakib01,
The help file for SDK (C:\Program Files\Solid Edge ST6\SDK\sesdk.chm) has more than enough examples to help you.
I use AddBy2Points method. I suggest storing all of your x & y co-ordinates in an excel spreadsheet and use an iterative loop to add a line for each iteration.
All of this can be done with VB.
