Need to save flat dxf...
I have seen a few examples on here but they will automatically pick the face and edge and save the dxf.... is there a way to only save if there is a flat model already associated with the sheet? otherwise i need it to ignore that file...
if the flat model already exists i need it to use those face and edges....
ideas?
Posted by: maury terneus
Post date: 2/22/2011 1:57:14 PM
RE: Need to save flat dxf...
If objPsmDoc.FlatPatternModels.Count = 0 Then
Posted by: Krzysiek Kozlowski
Post date: 3/15/2011 12:05:01 AM
