New to Solid Edge AddIn development
I have started developing an AddIn for Outlook and found it very easy with the actual version of Visual Studio (Community 2015) and the VSTO integration.
So I wonder if it is the same with Solid Edge. I have donwloaded the "Solid Edge Community AddIn" but when I start a new project and select it as a start I then get this error message:
What should I do to start in a proper manner ?
Thanks in advance
Francesco
Re: New to Solid Edge AddIn development
I suggest you check out this video made by Jason Newell. https://www.youtube.com/watch?v=Ji28nedYCCQ
It sounds to me, like you havent downloaded the NuGet Packages the community AddIn is Using.
In the linked video all this is explained.
Hope it helps,
Thomas
