Newbie question
Hi all
Newbie to SolidEdge and Cad programs but experienced programmer. This is probably a simple question but I'm stuck. Using C#, and I create a new instance of SE by code.
This code snippet gives me all variable names but how do I get the current values?
                doc = (SolidEdgeAssembly.AssemblyDocument)application.ActiveDocument;
                variables = (SolidEdgeFramework.Variables)doc.Variables;
                variableList = (SolidEdgeFramework.VariableList)variables.Query("*", null, null, false);
                for (int i = 1; i
                    oVariable = variableList.Item(i);
                    MessageBox.Show(variables.GetName(oVariable));
            catch (Exception ex)
Kjell-åke
Posted by: Kjell-Ake Boberg
Post date: 8/26/2009 2:44:34 AM
RE: Newbie question
try with:
MessageBox.Show(oVariable.Value)
JR
Posted by: JR
Post date: 8/27/2009 3:13:35 AM
RE: Newbie question
Posted By JR on 08/27/2009 8:13 AM
try with:
JR
Mmm.... not working I'm afraid. I have tried MessageBox.Show(oVariable.ToString()) but that gives the text "System.__comobj". Should be a quite common task but I'm stuck. When setting a value you can use variables.Edit("VarName","123") but I can't find a way to just read the value.
As the oVariable is declared as an "object" there might be necessary to do a typecast in order to read the value but I don't know which type to cast to.
Kjell-Åke
Post date: 8/27/2009 5:23:43 AM
RE: Newbie question
try with this declarations:
SolidEdgeFramework.variable oVariable = null;
string val;
and later with:
oVariable = (SolidEdgeFramework.variable)variableList.Item(i);
oVariable.GetValue(out val);
MessageBox.Show(val);
Posted by: JR
Post date: 8/27/2009 11:19:14 PM
