No Items from SurfaceFinishSymbolDataSets
I try to get the items from a SurfaceFinishSymbolDataSets (from Draft-File with vb.net 2010).
I can "add" and "remove" a SurfaceFinishSymbolDataSet in SurfaceFinishSymbolDataSets but i get an error by "item" and "count".
Is it a bug from ST3?
JR
Posted by: JR
Post date: 6/21/2012 6:48:46 AM
Re: No Items from SurfaceFinishSymbolDataSets
JR,
Thanks for reporting this. Were you seeing E_NOINTERFACE when trying those two methods? I believe I've reproduced the error.
-Jay
Posted by: Jay Carlton
Post date: 6/26/2012 3:19:01 PM
JR,
This issue is now logged as PR #6737721.
By the way, how did you verify that Add and Remove are working if Item and Count aren't? Do you have any sample code I can add to the PR?
Thanks again,
Jay
Post date: 6/26/2012 4:33:09 PM
Jay,
you can see "add" and "remove" directly/manualy in the Draft. if you know the name of SurfaceFinishSymbolDataSet
Example:
Dim objApp As SolidEdgeFramework.Application = Marshal.GetActiveObject("SolidEdge.Application")
Dim objDoc As SolidEdgeDraft.DraftDocument = objApp.ActiveDocument
Dim objSurfs As SolidEdgeFrameworkSupport.SurfaceFinishSymbolDataSets
Dim objSurf As SolidEdgeFrameworkSupport.SurfaceFinishSymbolDataSet
objSurfs  = objDoc.SurfaceFinishSymbolDataSets
    'Add new Item, you can see it in the Draft directly
    objSurf = objSurfs.Add("Example1")
    'Count Error:
    'MsgBox(objSurfs.Count)
    'Item Error:
    'objSurf = objSurfs.Item(1)
    'You can remove any Item by name
    'objSurfs.Remove("Example1")
    Marshal.ReleaseComObject(objSurf)
    objSurf = Nothing
    Marshal.ReleaseComObject(objSurfs)
    objSurfs = Nothing
    Marshal.ReleaseComObject(objDoc)
    objDoc = Nothing
    Marshal.ReleaseComObject(objApp)
    objApp = Nothing
I miss also the Property "Name" by SurfaceFinishSymbolDataSet.
The remove works only with "Name" but how can i get the Name without Property "Name"?
JR
Posted by: JR
Post date: 6/27/2012 12:59:47 AM
