Not getting intellisense in c++
I am not able to get the intellisense on APIs in c++. COuld any body help me.. ? Does anybody access this still ?
Posted by: Folk
Post date: 11/16/2012 5:24:01 AM
Folk,
Historically, Visual C++ intellisense has been flaky. It was worse in older versions of Visual Studio but has gotten better in newer releases. If you do a google search on the topic, you will find workarounds that usually get things working again. I've also seen intellisense fail depending on how you've written your code. Again, flaky. It would help if you'd tell us what version of Visual Studio you're using as well as post an example solution (.zip).
Posted by: Jason Newell
Post date: 11/18/2012 12:44:16 AM
Thank you jason. actually i am using Visual studio 2010. and working on c++. i have imported libIDs to talk with Solid Edge. But i am not able to get the intellisense like other CADs. What i am doing currently is copying Apimethods from .tlh files and pasting. Could you please help..
thanks
Posted by: Folk
Post date: 11/18/2012 12:51:00 AM
Hi R.D Holland, Thanks a lot..
now i am able to work with intellisense. But only in Win32console application.. not in Class library aplication. Do you have any idea ??
Posted by: Folk
Post date: 11/21/2012 12:04:16 AM
