Number of actual drawing sheets?
Hi all,
  Does anyone know how to find the actual number of sheets on a drawing?
  I have checked lpDrawing->Sheets->Count an on my sample drawing, it returns 11 as the qty.  Using SESpy, it also returns 11 with eleven items. - But only two of these items are the sheets I am interested in (ie In SolidEdge, there are two tabs, labelled "Sheet 1" and "Sheet 2".)  I am not interested in the number of background sheets, just the 'actual' sheets.
  Does this make sense as a question and if so, any suggestions on finding which of those 11 sheets are the actual sheets I want the quantity of?
Chris.
Posted by: chris mann
Post date: 10/17/2008 2:43:07 AM
RE: Number of actual drawing sheets?
In the past the method I used was:
TrueCount = 0
for i = 1 to seApp.ActiveDocument.Sheets.Count
If seApp.ActiveDocument.Sheets.Item(i).BackgroundVisible = True Then
TrueCount = TrueCount + 1
End If
Next
- Bill
Posted by: Bill Ledbetter
Post date: 10/17/2008 2:50:23 AM
Dim draftDoc As SolidEdgeDraft.DraftDocument
Dim numSheets As Integer
numSheets = draftDoc.Sections.WorkingSection.Sheets.Count
Posted by: Michael Frayser
Post date: 10/17/2008 4:25:19 AM
Thanks, Bill - That has done the trick nicely!
Chris.
Post date: 10/17/2008 5:08:51 AM
Michael,
Thanks too! - Of the two options, I'm going with yours - seems a little more direct!
Chris.
Post date: 10/17/2008 5:16:32 AM
Not a problem.
You can repay me by giving me the solution to my post from yesterday!
Post date: 10/17/2008 6:10:02 AM
