Hi, I want write a program which could first open the part file and then update the variables, but now i have a problem . . . i wrote this program and i dont know what is wrong, thanks for help
Imports System.Runtime.InteropServices
Public Class Form1
    Dim objApplication As SolidEdgeFramework.Application = Nothing
    Dim objPart As SolidEdgePart.PartDocument = Nothing
    Dim objVariables As SolidEdgeFramework.Variables = Nothing
    Dim objVariable As SolidEdgeFramework.variable = Nothing
    Dim objDocuments As SolidEdgeFramework.Documents
    Dim objApp As SolidEdgeFramework.Application
    Dim val1 As String
    Dim strValue As String
    Dim strName As String
    Const TESTFILE = "E:\VBA\part_2.par"
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        objDocuments = objApp.Documents
        Call objDocuments.Open(Filename:=TESTFILE)
        objApplication = Marshal.GetActiveObject("SolidEdge.Application")
        objPart = objApplication.ActiveDocument
        objVariables = objPart.Variables
        val1 = Val(TextBox1.Text)
        strValue = (val1 - 130) / 2
        strName = "tworz_1"
        objVariables.Edit(strName, strValue)
    End Sub
Posted by: Rafa P
Post date: 3/25/2010 10:16:25 AM
