Object highlight
How can i highlighting a occurrence, finding it by the occurrence name...
Aldo.
Posted by: Aldo Kruger
Post date: 11/8/2005 2:30:08 AM
RE: Object highlight
Aldo,
This is usually accomplished by using the SelectSet.Add() method. I have not tried it with occurrences.
Try something like objAssembly.SelectSet.Add(...)
You can also use Solid Edge Find to see if my theory is correct. Open an assembly, select the occurrence and check in Solid Edge Find if the Application.ActiveDocument.SelectSet has data.
Let me know if you still need help and I'll try to code an example for you.
Posted by: Jason Newell
Post date: 11/8/2005 2:33:56 AM
Hello Aldo
I 'cut&paste'd this out of a project of mine.
Private HighLight As SolidEdgeFramework.HighlightSet
Private objapp As SolidEdgeFramework.Application
Private objdoc As solidedgepart.PartDocument
Private highsets As HighlightSets
Set objapp = GetObject(, "SolidEdge.Application")
Set objdoc = objapp.ActiveDocument
Set highsets = objdoc.HighlightSets
Set HighLight = highsets.Add
'Aldo, in between thes lines, get the object you need wich i called YourObject
HighLight.AddItem yourObject
HighLight.Color = vbYellow
HighLight.Draw
'now your object should be highlighted in the color yellow
HighLight.RemoveItem (HighLight.Count) 'remove the last added object from your highlightset
HighLight.Draw
'set everything to nothing
Set Highlight=Nothing
Set Highsets=Nothing
Set objdoc=Nothing
Set objapp =nothing
If you step trough thisone, it should help you to understand the highlightset.
A highlightset is a different thinh then a selectionset.
It is also possible to create different highlightsets, each with a different color, all in the same view, so you can, for instance, highlight edges in yellow, faces in cyan, keypoints in green,...
good luck!
Kris.
Posted by: Kris Verheyen
Post date: 11/8/2005 7:45:32 AM
Tanks for all...
I make this,
Dim objHighlightSets As SolidEdgeFramework.HighlightSets
Dim objHighlightSet As SolidEdgeFramework.HighlightSet
Dim Occ As SolidEdgeAssembly.Occurrence
Dim i As Integer
Try
pg.SelectedObject = oDocs(tvw.SelectedNodes(0).Tag)
'Dim objDoc As SolidEdgeAssembly.AssemblyDocument
Dim objDoc As Object
Try
objDoc = p_application.ActiveDocument
If Not objDoc Is Nothing Then
Dim wind As SolidEdgeFramework.Window
objHighlightSets = objDoc.HighlightSets
'clear the HighlightSets object
For i = 1 To objHighlightSets.Count
objHighlightSets.Item(i).RemoveAll()
Next
wind = objDoc.Windows.Item(1)
wind.View.Update() 'redraw the window
'create a new HighlightSet object
objHighlightSet = objHighlightSets.Add()
For Each Occ In objDoc.Occurrences
'if the occurrence name equal as the tree selected object
If tvw.SelectedNodes(0).Text = Occ.OccurrenceDocument.Name Then
'add's it to the HighlightSet
objHighlightSet.AddItem(Occ)
End If
Next
'draw the HighlightSet object
objHighlightSet.Draw()
End If
Catch ex As Exception
MessageBox.Show(ex.Message)
End Try
Catch
End Try
And it's works with Occurrences objects.
Post date: 11/8/2005 10:27:24 AM
Looks like someone has a custom Addin .
Where did you find that TreeListView control?
Post date: 11/8/2005 10:34:52 AM
TreeListView Control
http://www.codeproject.com/cs/miscctrl/extendedlistviews.asp
Post date: 11/8/2005 10:42:59 AM
Jason,
I have a problem using a imagelist in the treelistview, after using the releasebuild utility, the edgebar not display after releasebuild.
Please can you help me - where is my problem.
Thank you...
Aldo.
Post date: 11/8/2005 10:48:17 AM
Nice, thanks for the url. It's funny because I frequent that site often and have never seen that particular article. Nice find.
Post date: 11/8/2005 10:48:23 AM
Aldo,
You'll have to modify the ReleaseBuild.bat. Look at the following example. I've bolded the lines you need to look at. Obviously, change the names to match yours.
The thing that you're looking for are .resx files in your project folder. Anytime you add graphics to a control, they get stored in the .resx which means the build is slightly different.
Let me know if you still have trouble. We'll get you going because I'm familiar with this one.
ECHO OFF
CLS
SETLOCAL
PUSHD %VS71COMNTOOLS%
@call vsvars32.bat
POPD
resgen About.resx SEAddin3.About.resources
SET CSCARGS=
SET CSCARGS=%CSCARGS% /win32res:Addin.res
SET CSCARGS=%CSCARGS% /resourceSmiley FrustratedEAddin3.About.resources
SET CSCARGS=%CSCARGS% /target:library
SET CSCARGS=%CSCARGS% /out:./bin/Release/SEAddin3.dll
SET CSCARGS=%CSCARGS% /reference:
SET CSCARGS=%CSCARGS%./bin/Release/Interop.SolidEdgeFramework.dll;
SET CSCARGS=%CSCARGS%./bin/Release/Interop.SolidEdgeConstants.dll;
SET CSCARGS=%CSCARGS% *.CS
CSC %CSCARGS%
regasm /nologo /silent /codebase ./bin/Release/SEAddin3.dll
ENDLOCAL
ECHO Compile Complete
pause
Post date: 11/8/2005 10:55:20 AM
Hi Guys,
a bit off topic...
I'd stumbled accros the TreeListView article before (nice control), but what I'd like to know is where you got the VS.Net style properties ListView (under the TreeListView in the screenshot)?
Calum
Posted by: Calum McLellan
Post date: 11/9/2005 5:50:10 AM
