Occurence Properties
How can i read the occurence property table?
Specifically, I am trying to see if Assembly Reports is Yes or No.
Thanks!
Re: Occurence Properties
try: ActiveDoc>Occurences
each occurence should be an item in the assembly (either it be a part or sub assy).  As occurance, you look for "IncludeInBom".
Remember, things get tricky if you want to look into any sub assys.  Those are subOccurances.  I suggest finding Jason Newell's "Solid Edge Spy".  It does wonders for looking at the structure of documents.
-Dave
Dave,
Thank you!  I havnt tried it yet, but IncludeInBom def looks like what im trying to do.
I am already looping through occurances and subocurances so that is not a problem. And i am already using the spy! Thanks a bunch!
