Occurrence.GetMatrix not working
I made an assembly with 2 parts, and used Occurrence Properties interactively to move the parts about.  In my program, I'm calling GetMatrix on the part occurrence and am getting a 0 matrix. (Not even an identity.)  What's wrong?
      foreach (Occurrence x in doc.Occurrences)
        var d = x.OccurrenceDocument;
        double[] docmat = new double[16];//       Array.CreateInstance(typeof(double), 16);
        x.GetMatrix(docmat);
Re: Occurrence.GetMatrix not working
I'll take a look at this tonight when I get home and let you know what I find.
Jason Newell
Applications Architect
www.jasonnewell.net
Here is some sample code that should explain everything. I also demonstrated how to leverage extension methods to make the matrix conversion from Array -> double[] cleaner. Let me know if you have any questions.
using SolidEdgeCommunity;
using SolidEdgeCommunity.Extensions;
using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace CSJunk
    class Program
        [STAThread]
        static void Main(string[] args)
            var application = SolidEdgeUtils.Connect();
            var assemblyDocument = application.GetActiveDocument<SolidEdgeAssembly.AssemblyDocument>();
            var occurrences = assemblyDocument.Occurrences;
            var occurrence = occurrences.Item(2);
            // Demonstrate getting matrix of type Array.
            var matrixArray = Array.CreateInstance(typeof(double), 0);
            occurrence.GetMatrix(ref matrixArray);
            // Demonstrate converting matrix of type Array to double[].
            var matrix = matrixArray.OfType<double>().ToArray();
            // Demonstrate using extension method to get matrix of type double[].
            matrix = occurrence.GetMatrix();
    public static class OccurrenceExtensions
        public static double[] GetMatrix(this SolidEdgeAssembly.Occurrence occurrence)
            Array matrix = Array.CreateInstance(typeof(double), 0);
            occurrence.GetMatrix(ref matrix);
            return matrix.OfType<double>().ToArray();
Jason Newell
www.jasonnewell.net
