Occurrence overides
First of all I am on SE V15, in case the funcality I am looking for might already exist on a newer version. What I would like to do is similar to what the current "occurrence properties" function already does. Some how ( and I would like to know how) SE is able to attach overides to individual parts, (bom exlude, user defined qty. ect...) but stores that info in the .asm file and not the .par file. What I would like to do is be able to overide other things, for example I would have a .par file with the spare parts columb set to S1 meaning that part is a spare needing replaced every 3yrs. But on certain .asm files that part is used on, I want to be able to overide that field, as that part would not be considered a spare on that certain assembly. Is there anything like that out there, or does anyone have any suggestions for me.
Thankx,
Chris
Posted by: Chris Estelle
Post date: 11/10/2005 6:39:37 AM
