Occurrence v. Frame member
Do you know a method or process, how recognize structural frame member and "normal" occurrence?
I have an assembly with a few structural frames and normal parts (occurrencies). And now I need export  BOMs which they have separatly normal parts and separatly frame members.
A problem is that each frame member is a occurrence too. I had a idea use Occurrence Property "HasBodyOverride". In case that occurrence is normal part is "False", in case that occurrence is frame member is "True".
A 2nd problem is if the assembly has AssemblyFeature within normal part then a occurrence has property HasBodyOverride = True.
Have somebody a other idea?
Posted by: Vaclav Blahnik
Post date: 7/27/2009 3:52:06 AM
