Official SDK documentation
Dear All, I'm looking for some documents [script removed]
But, where can I find official documentation about  Type Libraries and all methods in ours disposal?
OLE is the only  way for SolidEdge programming?
Thanks.
Marco
Posted by: Marco Bombardieri
Post date: 1/19/2009 10:45:18 PM
RE: Official SDK documentation
HI Marco,
1. you can find great samples and presentation here on JasonNewell site.
2. you can find documentation in the help with solidedge.
3. Also on http://support.ugs.com, Documents, you can find programming manuals for SolidEdge.
Massimo
Posted by: Massimo Magris
Post date: 1/20/2009 6:18:35 AM
Hi Marco,
In addition to what Massimo said, you can get to the Programmer's Guide and SDK Help via Solid Edge.  See attached screenshot.  The Programmer's Guide and SDK Help for Solid Edge ST were completely rewritten and is very up to date.
Take a look at my Downloads section.  You should also install my free Solid Edge Spy application which can be found in the Products section.  I've also started updating http://wiki.jasonnewell.net/SDK.ashx.  Solid Edge's API is COM based so you can use any programming\scripting lanuage that supports it.
Posted by: Jason Newell
Post date: 1/20/2009 7:31:34 AM
OK.
my problem is that I've to choose the right 3d CAD for my purpose... I've not the license yet. So, no help and no docs...
but for the moment I've got an idea about SolidEdge can do. and I know that I can find great help here.
Thanks..
Post date: 1/20/2009 11:44:06 PM
