Opening Assy file props when Assy has alternate Configs
Hi All
Ummm just a bit stuck. I'm trying to access the file props of an assy that has alternate configs. But i get not valid path.I've tried stripping all the infomation off the end of the file path but still no go
any ideas wood be most welcome
Sorry it's in VB but i could read between the line if required
Thanks Snow
Set objProps = CreateObject("SolidEdge.FileProperties")
If (objOccurrence.IsFamilyOfAssembly) Then  'check if has alternate assy info attached
    x = 0
    a = 0
    Filename = (objOccurrence.OccurrenceFileName)
    LenFileName = Len(Filename)
    'Filter out junk in file path
    For x = LenFileName To 1 Step -1
        a = a + 1
        Test = Mid(Filename, x, 1)
        If Test = "." Then
            Filename = Mid(Filename, 1, x + 3)
            Debug.Print Filename
        End If
Next x
 Debug.Print Filename   'Check to see what at been stripped
 objProps.Open (Filename)  'Open file ------------------bombs out here
    Else:
    objProps.Open (objOccurrence.OccurrenceFileName)  'Not a alternate Assy so just open it
End If
Posted by: Snow Mackenzie
Post date: 9/4/2008 7:28:29 PM
RE: Opening Assy file props when Assy has alternate Configs
Hi Snow,
it looks like you're trying to access the properties of a file that is open in Solid Edge. You  can't do that with the SE file properties API - even opening read only won't work.
You could try the Occurrence.Properties property, or you could try my FileProps API (written for VB6 ) here (make sure to set the readonly flag when opening): http://www.jasonnewell.net/Forums/tabid/55/forumid/1/tpage/1/view/topic/postid/831/Default.aspx#831
Cheers
Calum
Posted by: Calum McLellan
Post date: 9/4/2008 9:22:07 PM
Hi Calum
Yahoo. This might get me right out of the ...Ummm ....well ....4 letter word starts with C and end with P. Might have to shout you a DB when you get back to CHCH
Will keep you posted how I get on
Spot  ya
Snow
Post date: 9/5/2008 12:15:39 AM
Better make that a monteiths (You can take the coaster out of the coast,... )
Post date: 9/5/2008 12:22:54 AM
Hi Calum
Had massive success with your DLL ,it realy rocks. Now I can open and shut almost anything...
I would e-mail you a  monteiths but i can't seem to fit the bottle in my USB port.
Thanks Again
Snow
Post date: 9/5/2008 12:33:08 AM
