Operation unavailable (Exception from HRESULT: 0x800401E3 (MK_E_UNAVAILABLE))
I am  developing web application with help of solid Edge Dlls. My Web application is working fine in my local system , i hosted this web application into IIS.
But whenever trying to connect a running instance of Solid Edge  from the other system then it is giving below Error.
Note: This is Web application not Window or Desktop Application.
Please suggest me.
3 REPLIES 3
Re: Operation unavailable (Exception from HRESULT: 0x800401E3 (MK_E_UNAVAILABLE))
Where is your Solid Edge installed - I guess its on the server.
I have heard some colleagues some time ago mentioning about creating a service which would invoke SE on the server and exchange data between the web client and the server.
Does your web application work in a similar fashion ?
I made a video and wrote a blog addressing the issue. See if it helps.
Solid Edge Automation via IIS
Jason Newell
Solutions Architect
www.jasonnewell.net
Just curious. Did you get past your problem?
Jason Newell
Solutions Architect
www.jasonnewell.net
