Out of memory SE V20
    Can we get some exception etc in vb.net program when solidedge V20 goes out of memory?
Posted by: Mithun **bleep**ole
Post date: 5/17/2009 7:41:51 PM
RE: Out of memory SE V20
Not that I know of.
Posted by: Jason Newell
Post date: 5/19/2009 12:09:43 PM
oh.. so nothing can be done to stop application behaving crazily when SE goes out of memory!! Smiley Sad
Post date: 5/20/2009 2:44:50 AM
Dear Mithun,
When Solid Edge has memory problems. It are memory problems. You have to consider to put more memory in you PC.
You can also restart Solid Edge by yourself. When you open and close a lott of models etc. The memory banks keep a bit of information.It builds up (you can see the build up in your task manager). It will only clear when you close Solid Edge and restart.
Regards Leon
Posted by: Leon Brouwer
Post date: 5/20/2009 4:06:24 AM
