PartCopy varaible reading
Hi All,
I need to read the part copy variable programmatically. I am using VB.NET. Please guide me..
Posted by: Nudrat Hassan
Post date: 12/16/2008 6:03:55 PM
RE: PartCopy varaible reading
Here is a snippet from a code I wrote in C# that works:
m_document = (SolidEdgeFramework.SolidEdgeDocument)m_application.ActiveDocument;
RevisionManager.Application revisionManagerApplication = new RevisionManager.Application();
RevisionManager.Document revisionManagerDocument = (RevisionManager.Document)revisionManagerApplication.Open(m_document.FullName, RevisionManager.RevisionRuleType.LatestRevision, true);
RevisionManager.LinkedDocuments linkedDocuments = (RevisionManager.LinkedDocuments)revisionManagerDocument.get_LinkedDocuments(RevisionManager.LinkTypeConstants.seLinkTypeAll);
if (linkedDocuments.Count > 0)
RevisionManager.Document linkedDocument = (RevisionManager.Document)linkedDocuments.get_Item(1);
string linkedPartFullName = linkedDocument.FullName;
I hope it will help you
Adar
Posted by: Adar Shtainhart
Post date: 2/15/2009 9:57:40 PM
