Parts List from Draft Envirronment
Hello Edgers,
Is there a way to get the parts list from the draft environment. Basically if there is a parts list on the draft sheet I want to extract it.
thanks
Paul Martz
National steel car
Posted by: Paul Martz
Post date: 11/15/2005 1:57:00 AM
RE: Parts List from Draft Envirronment
Paul,
Open your SDK documentation and search for 'PartsList Object'. The PartsList object has a CopyToClipboard() method. You can also use Solid Edge Find to browse the object structure. It should be something like Application.DraftDocument.PartsLists.PartsList.....
That's all I've got
Posted by: Jason Newell
Post date: 11/15/2005 2:13:46 AM
