Parts List, include columns and rows and Delete
Hello!
I created a VB code that corresponds to the PartsList command.
What I'm trying now is to access the properties through a Part ListPartsList Properties -> Data, and have access to rows, columns, and can delete them or add new lines.
Can you help me?
See the code snippet.
The Dim objApplication SolidEdgeFramework.Application = Nothing
The Dim objDocument SolidEdgeFramework.SolidEdgeDocument = Nothing
The Dim objDraft SolidEdgeDraft.DraftDocument = Nothing
The Dim objModelLink SolidEdgeDraft.ModelLink = Nothing
The Dim objDrawingView SolidEdgeDraft.DrawingView = Nothing
The Dim objDrawingViews SolidEdgeDraft.DrawingViews = Nothing
The Dim objSheets SolidEdgeDraft.Sheets = Nothing
The Dim objSheet SolidEdgeDraft.Sheet = Nothing
The Dim objModelLinks SolidEdgeDraft.ModelLinks
Dim view As Object = ""
The Dim ObjPartlist SolidEdgeDraft.PartsLists
The Dim ObjPart SolidEdgeDraft.PartsList
Try
objApplication Marshal.GetActiveObject = ("SolidEdge.Application)
MessageFilter.Register ()
objDocument = objApplication.ActiveDocument
If (objDocument.Type DocumentTypeConstants.igDraftDocument) Then
MessageBox.Show ("The list of material to be generated from a draft." Failed "in the type of file", MessageBoxButtons.OK, MessageBoxIcon.Information)
Exit Try
End If
objDraft = objApplication.ActiveDocument
GOOD = New ClassBOM
objModelLink objDraft.ModelLinks = (0)
objModelLink.UpdateViews ()
ProcessAssembly (objModelLink.ModelDocument)
objModelLinks = objDraft.ModelLinks
objSheet = objDraft.ActiveSheet
objDrawingViews = objSheet.DrawingViews
For Each objDrawingView In objDrawingViews
view = objDrawingView
'ObjDrawingView.Delete ()
Next
ObjPartlist objDraft.PartsLists = ()
If ObjPartlist.Count = 0 Then
objDraft.PartsLists.Add (View, "ISO", 0, 1)
Else
For Each ObjPart In ObjPartlist
ObjPart.Update ()
Next
End If
Catch ex As Exception
If objApplication Is Nothing Then
MessageBox.Show ("SolidEdge not found.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
Else
MessageBox.Show (ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End If
Finally
If Not (objApplication Is Nothing) Then
Marshal.ReleaseComObject (objApplication)
objApplication = Nothing
End If
If Not (objDocument Is Nothing) Then
Marshal.ReleaseComObject (objDocument)
objDocument = Nothing
End If
If Not (objDraft Is Nothing) Then
Marshal.ReleaseComObject (objDraft)
objDraft = Nothing
End If
If Not (objModelLink Is Nothing) Then
Marshal.ReleaseComObject (objModelLink)
objModelLink = Nothing
End If
End Try
End
Posted by: Edson Silva de Jesus
Post date: 12/30/2010 6:15:49 AM
