Partslist CopyToClipboard
Today I started working on our customized partslist. I used to be able to copy the partslist's contents to clipboard for further use outside SE. This was with V20.
Since we installed ST2, the same code doesn't seem to work anymore. It crashes at the CopyToClipboard method for the PartsList.
It gets a Runtime error 430 "Class does not support Automation or does not support expected interface" in VB6.
VB.NET gives the following error:  HRESULT: 0x80004002 (E_NOINTERFACE))
Any idea how to fix this? I need to extract the PartsList's contents and I don't know any  other way.
Edit: update and delete functions work just fine for the partslist. Other CopyToClipboard commands work fine aswell (for Variables for example). Partslist.CopyToClipboard just won't work.
Edit2: CopyToClipboard for PartsLists is bugged. The method doesn't work in the API.
Posted by: T. Jissink
Post date: 11/3/2009 11:24:16 PM
RE: Partslist CopyToClipboard
I also encounter similar question:
pPartList->CopyToClipboard();
it is do not work in SE ST2.
Can somebody help me? Thanks!
Posted by: illuminiti illuminiti
Post date: 3/31/2011 3:13:28 PM
It has been working for me flawlesly in 32 and 64 bits. Perhaps it's a problem related with Maintenance Pack? Are you up to date?
Posted by: Julian Guillo
Post date: 3/31/2011 10:37:33 PM
Thank you,at first.
I have not heard of this. I find it online more than 1G , is it really and need to register to download?
Can you give me or advise?
Post date: 4/1/2011 5:30:09 PM
After installing th patch I have solved the problem.
Thanks,again.
Post date: 4/1/2011 8:32:31 PM
