Physical Properties - Mass of a cord Weld!?
Hello everybody,
In my application, my client wants to know how much in kg of material was used in a solder joint!
For this I need to know the mass was restricted to weld applied to my set!
But I could not find any function or property that I return it and I have no idea how to do it!
I need help with this!
Does anyone have an idea how can I get that body?
Thank you!
Posted by: Fabio Rosa
Post date: 10/23/2009 8:59:02 AM
RE: Physical Properties - Mass of a cord Weld!?
You can suppress the welds in the AssemblyFeatures and update the physical properties of the Assembly. The difference, between suppressed and not suppressed AssemblyFeatures, is the weight what you need.
Posted by: JR
Post date: 10/26/2009 12:24:43 AM
Thank you!
I will implement this method!
Post date: 10/26/2009 1:26:49 AM
