Physical Properties
Actually i have to do a few basic things in solid edge using c++i have minimal knowledge of C++ as well as solid edge commands.All i want to do is to obtain physical properties of a part already modeled in solid edge.but i have to collect the properties through a program.
I linked the program variables with Excel sheet ,now if i can obtain the properties of the modle using C++ it will do,also the modle is updated several times so properties are required each time the modle is updated..kindly help me.
prasad ,sorry for disturbing you on your email brother.
Ali
Posted by: ali kamran
Post date: 10/22/2008 3:35:50 AM
