Pick a dimension with mouse click event on draft
Hi
I need to pick the dimension measure with Smart Dimension when the user click on it, what i've tried is pick the variable value on the click event, but i didn't found this in solid edge API, does anybody know how to do that?
Posted by: Marcelo Marques
Post date: 7/16/2012 9:36:14 AM
Re: Pick a dimension with mouse click event on draft
You can use the event like this (vb.net)
Dim WithEvents objCommand As SolidEdgeFramework.Command
Dim WithEvents objMouse As SolidEdgeFramework.Mouse
private sub test()
objApp = Marshal.GetActiveObject("SolidEdge.Application")
objCommand = objApp.CreateCommand(2)
objMouse = objCommand.Mouse
objCommand.Start()
end sub
Private Sub objMouse_MouseClick(sButton As Short, sShift As Short, dX As Double, dY As Double, dZ As Double, pWindowDispatch As Object, lKeyPointType As Integer, pGraphicDispatch As Object) Handles objMouse.MouseClick
'pGraphicDispatch is your dimension
End Sub
Posted by: JR
Post date: 7/18/2012 7:51:02 AM
