Place Part in ST2???????????
I'm trying to programmically place a part interactively in ST2 using VB.NET.
I'm using seApp.StartCommand(sePlacePartCommand) , passing the filename in the onPlacePartUI event.
This always used to work OK before. Not now, in ST2.... Good old Siemens. I get this message in SE....
Any other way of doing this, or suppressing this silly message?
Cheers,
David Rothan
SysRq
Posted by: Dave Rothan
Post date: 5/18/2010 2:00:06 AM
RE: Place Part in ST2???????????
Missed one vital step in my half-asleep state...
Wasn't setting my FileEvents object to seApp.FileUIEvents.
Done that, but now get:
"Unable to cast COM object of type 'System.__ComObject' to interface type 'SolidEdgeFramework.FileUIEvents'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{351BD72F-2103-3431-80F5-417185F2168F}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE))."
Any clues?
Post date: 5/18/2010 2:15:48 AM
Sorted.. Needed to use ISEFileUIEvents_Event instead.
Can someone explain the subtle, yet confusing differences between ISEFileUIEvents_Event and FileUIEvents? In fact what the mystery is behind all of the ISE prefixed events and their significance?
Post date: 5/18/2010 2:28:51 AM
^ that's what I'm also interrested in!
Jason once told me, too to alwase use the "ISE...._Events" with vb.net ...
but why?
Posted by: Linus Hechinger
Post date: 5/18/2010 11:08:53 PM
OK, for the benefit of others, this is what I did:
Dim seApp As SolidEdgeFramework.Application
Dim WithEvents seFileUIEvents As SolidEdgeFramework.ISEFileUIEvents_Event
Sub PlaceInSE()
seApp = GetObject(, "SolidEdge.Application")
seFileUIEvents = seApp.ApplicationEvents
seApp.StartCommand(SolidEdgeFramework.SolidEdgeCommandConstants.seAssemblyPlacePartCommand)
End Sub
Private Sub seFileUIEvents_OnPlacePartUI(ByRef Filename As String, ByRef AppendToTitle As String) Handles seFileUIEvents.OnPlacePartUI
Filename = "C:\TestPart.par"
End Sub
Post date: 5/18/2010 11:34:12 PM
