Populate properties on select set
Hi All
I'm looking at an APP that would allow me to create/populate properties on the select set.
Example, I select  part(s) and/or assembly(ies) and  from there I could create a new property(ies) for each occurence of the select set and associte a value to the new property.
Same, if common porperty exist, change its value for all the occurence in the select set.
