Position of occur wrt to the SE MASTER ASSEMBLY
Hi everyone,
the function getorigin:
<occurenceobjectname>.getorigin(x,y,z) would give the position with respect to the closest assembly in which it lies....
Therefore, in the case of multi-level assemblies, this function can not help in getting the position of the occurence with repect to the master assembly....
I need to get the position wrt the master assembly(master occurence).
I'm using SET3 and "interop.solidedgeassembly.dll(VERSION 1.0.0.0)"....
Please help out, I'm a beginner in Solid Edge...............
Posted by: Jacob Andrews
Post date: 9/14/2012 10:58:17 AM
GetTransform may help.
Posted by: Terry Tyson
Post date: 9/25/2012 7:38:21 AM
