Powertoy deployment
PLM World Member Genius PLM World Member Genius
Is there anyone using the powertoy version 1.4.0.0
I wanted to push  the configuration on my station to other station without having to redo the whole process of define custom properties etc...
Is there a set of registry key I can copy from one station and paste to another one.
Re: Powertoy deployment
Luc,
As the author of PowerToys, I would strongly suggest you reconsider the use of PowerToys. While it does have cool functionality, it is not supported and development has been terminated. My suggestion is that share your interest in the functionality with Dan's team.
Jason Newell
Applications Architect
www.jasonnewell.net
Hi Jason
Thank you for your reply, as of now it help answer needs I have.
But I will sure do some follow-up with Dan's team
Are you at SEU14 next week?
