Preview a picture box
Congratulations for the site.
I'm new and want to know if you can preview a picture box  ( *.par or *.asm)
If you what the code should I enter?
Thank you in advance
language Vb.net
Posted by: Sem Sem
Post date: 10/22/2009 7:41:24 AM
RE: Preview a picture box
You did not specify what programming language you use so it's hard to give an example. I can give you hints though.
Add a reference to sethumbnail.dll for thumbnail previews that you can show in a picture box. There is a SeThumbnailExtractor class and it has a GetThumbnail() method that will give you a handle to a bitmap that you can work with. For more complex previews, you can use the SEPreview.ocx as an ActiveX embedded object.
Posted by: Jason Newell
Post date: 10/22/2009 7:47:54 AM
can i get the sample how to use SE thumbnail in C#
Posted by: Rajganesh S
Post date: 7/20/2011 2:39:15 AM
example:
private void Get_Image(string sFileName)
int hImageSE;
Image imagePic;
SeThumbnailLib.SeThumbnailExtractor SEThumb=new SeThumbnailLib.SeThumbnailExtractor();
SEThumb.GetThumbnail(sFileName, out hImageSE);
IntPtr iPImage = new IntPtr(hImageSE);
imagePic = Image.FromHbitmap(iPImage);
// imagePic.Save(sFileName + ".png", System.Drawing.Imaging.ImageFormat.Png);
imagePic = null;
if (SEThumb != null) {
System.Runtime.InteropServices.Marshal.ReleaseComObject(SEThumb);
SEThumb = null;
Best Regards
JR
Posted by: JR
Post date: 7/27/2011 11:39:15 PM
