Printing a .dft using vba in excel
hi
I have trouble writing a code that can print a dft.
heres my code:
Option Explicit
Sub PrintDraft()
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgeDraft.DraftDocument
Dim objSheet As SolidEdgeDraft.Sheet
Dim FilePath_VA As String
Dim PrinterName_VA As String
Dim SEprinter_VA As String
'sets the filename to be printed = draftfile called "drawing.dft" located in the same folder as this excelsheet
FilePath_VA = ThisWorkbook.Path & "\drawing.dft"
'sets the printer to the default systemprinter
PrinterName_VA = Application.ActivePrinter
On Error Resume Next
'opens solid edge
Set objApp = GetObject(, "SolidEdge.Application")
If Err Then
Err.Clear
Set objApp = CreateObject("SolidEdge.Application")
Set objDoc = objApp.Documents.Open(FilePath_VA)
End If
objApp.Visible = True '*****change false to true if you want to see the drawing being generated******
objApp.DisplayAlerts = False
Set objSheet = objDoc.ActiveSheet
SEprinter_VA = objApp.ActivePrinter
'*************************************I'm doing something wrong here? it doesn't work?*****
objDoc.PrintOut (SEprinter_VA)
Call objDoc.Close
Call objApp.Quit
Set objApp = Nothing
Set objDoc = Nothing
Set objSheet = Nothing
End Sub
Posted by: casper jensen
Post date: 7/21/2006 2:25:10 AM
RE: Printing a .dft using vba in excel
I used this code to fix my problem:
Option Explicit
' API function to find the default printer
Private Declare Function GetDefaultPrinter Lib "winspool.drv" Alias "GetDefaultPrinterA" (ByVal sPrinterName As String, lPrinterNameBufferSize As Long) As Long
' Function to find the default printer by "GetDefaultPrinter"
Public Function GetDefaultPrinterName() As String
Dim sLen As Long
Dim hResult As Long
GetDefaultPrinterName = Strings.Space$(255)
sLen = 255
hResult = GetDefaultPrinter(ByVal GetDefaultPrinterName, sLen)
If hResult 0 Then
GetDefaultPrinterName = Strings.Left(GetDefaultPrinterName, sLen - 1)
Else
GetDefaultPrinterName = ""
End If
End Function
Sub PrintDraft()
'opens solid edge
If Err Then
Err.Clear
End If
objApp.Visible = True '*****change false/true if you want to see the drawing ******
' Find the default printer using the API
SEprinter_VA = GetDefaultPrinterName
objDoc.PrintOut SEprinter_VA, Orientation:=2
Call objDoc.Close
Call objApp.Quit
End Sub
Post date: 7/30/2006 9:07:15 PM
tried the previous code, but some DFT s won't open... I can't figure out why, it happens to random dfts.
And if one dft doesnt work the first time it wont the 2nd and 3rd....
The code is pretty much the same as the last post, with a loop.
Option Explicit
Dim sLen As Long
Dim hResult As Long
sLen = 255
If hResult = 0 Then
Else
'GetDefaultPrinterName = ""
End If
End Function
Sub PrintDraft()
Dim x As Integer
'opens solid edge
If Err Then
Err.Clear
If Worksheets("Print List").Range("Q1").Value > 0 Then
For x = Worksheets("Print List").Range("Q1").Value To Worksheets("Print List").Range("R1").Value
If Worksheets("Print List").Range("P" & x).Value <> "" Then
FilePath_VA = Worksheets("Print List").Range("P" & x).Value
'Set objSheet = objDoc.ActiveSheet
Call objDoc.Close
End If
Next
End If
End If
Call objApp.Quit
End Sub
Posted by: Marc Turcotte
Post date: 1/17/2013 10:23:38 AM
