Printout SolidEdge Draft by VB6
I try to print draft by VB6(SP6). But,I don't know to specify 'Sheets'.
  Dim Pname As String    'Printer.DeviceName
  Dim NumC As Integer    'Number of Copy
  Dim Ori As Integer    'Orientation
  Dim Psize As Integer    'PaperSize
  Dim CAB As Boolean    'ColorAsBlack
  Dim p As String      'Sheets
  Set seapp = GetObject(, "solidedge.application") .
  Set act = seapp.ActiveDocument
  Ori = 1      '1Smiley Tongueortrait  2:landscape
  Psize = 9      'Papersize ID  9:A4
  CAB = True
  'Success
      act.printout Printer:=Pname, NumCopies:=1, Orientation:=Ori, PaperSize:=Psize, _
                      PrintRange:=3, Sheets:="1,3-5,8", ColorAsBlack:=CAB
  'Error
      p = "1,3-5,8"
                      PrintRange:=3, Sheets:=p, ColorAsBlack:=CAB
By SDK,all parameter is 'System.Object'.
What is problem ?
Posted by: Shoji Nakahara
Post date: 11/13/2012 9:44:23 AM
I hit a similar problem at VB.NET but there it is solvable by using the Marshalling or the ToAsciiArray function (not sure witch of them it was, it's a year ago I last time tried this).
I think the variable p has to be of type IntPtr (Long in VB I think, pointer to a place in memory) and you have to convert the 16 Bit UTF string to 8 Bit ASCII Char Array.
Posted by: Stefan Barlage
Post date: 11/14/2012 6:32:38 AM
Dear Stefan
Thank you for your help. I tried.
'p' sets 8bit char. VB6 does't have 'IntPtr' function, so It meets 'VarPtr' function,I think. But,It's not success.
'Error
  Dim pp as Long
  p = "1,3-5,8"
  pp = VarPtr(p)
                      PrintRange:=3, Sheets:=pp, ColorAsBlack:=CAB
I gave up by VB6. Then,not so cool procedure,I activate by every sheet, and printout by PrintRange sets Activesheet.
  acs.sheets.Item(i).Activate
                      PrintRange:=2, ColorAsBlack:=CAB
Post date: 11/20/2012 3:37:15 AM
