Problem in accessing variables in VC2008
I have written code to read the variables from variable table.I am able to read all the variables properly when I build my code in VC6.Recently I have migrated to VC 2008 and now Iam unable to access the variables .In my code which I have pasted below,  vlist_count returns  the correct value but pVar returns null.Please help me out.
IDispatchPtr vList_Disp = PtrAllVar->Query(pFindCriterium);
VariableListPtr vList = (VariableListPtr)vList_Disp;
 long vlist_count = vList->Count;
 for(long i=1;i
variablePtr pVar;
pVar = vList->Item(i);
Triadiantry{
SolidEdgeFramework::VariablesPtr
PtrAllVar=pPrtDoc->GetVariables();
Posted by: Shafi Shaik
Post date: 12/6/2009 10:07:51 PM
RE: Problem in accessing variables in VC2008
There was a mistake in my previous code snippet .The correct one is as follows: Dimensions are not accessible in VC++ 2008,and works fine in VC6.
SolidEdgeFramework::VariablesPtr PtrAllVar=pPrtDoc->GetVariables();
for(long i=1;i
variablePtr pVar;
try{
Regards.
Post date: 12/7/2009 8:43:14 PM
Triadian,
the items in the VariableList may be either of type Variable or Dimension. So you may try this:
if (NULL == pVar)
  DimensionPtr pDim = vList->Item(i);
  // do something with Dimension
else
  // do something with Variable
Posted by: Martin Bernhard
Post date: 12/11/2009 10:42:17 AM
