Problem with RenameFiles Method
I make this sample code to rename assembly file but my Asm file does not change after this action with the Revision Manager.
You have any idea?
My C# code:
RevisionManager.Application objApplication = null;
RevisionManager.Insight objInsight = null;
object filesToBeRenamed = null;
object destinationPathsOfRenamedFiles = null;
// Start Revision Manager.
objApplication = new RevisionManager.Application();
// Get reference to Insight object.
objInsight = (Insight)objApplication.Insight;
filesToBeRenamed = "\\\\MyLocal\\Assembly" + "\\" + "Part14.asm";
destinationPathsOfRenamedFiles = "\\\\MyLocal\\Assembly" + "\\"+"Part14.asm" + "1";
objInsight.RenameFiles(filesToBeRenamed, destinationPathsOfRenamedFiles);
//I have Pop up here from Revision Manager:
//With confirmation The folder already contains a document named Part14.asm1
//But I don't have this file Part14.asm1 in the folder \\\\MyLocal\\Assembly
//Look the attach file for more information.
Same with VB.Net
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
Dim objApplication As RevisionManager.Application = Nothing
Dim objInsight As RevisionManager.Insight = Nothing
Dim FilesToBeRenamed As Object
Dim DestinationPathsOfRenamedFiles As Object
Try
' Start Revision Manager.
objApplication = New RevisionManager.Application
' Get reference to Insight object.
objInsight = objApplication.Insight
FilesToBeRenamed = "C:\Assembly" + "\" + "Part14.asm"
DestinationPathsOfRenamedFiles = "C:\Assembly" + "\" + "Part11.asm"
objInsight.RenameFiles(FilesToBeRenamed, DestinationPathsOfRenamedFiles)
Catch ex As Exception
' Write any errors to console.
Console.WriteLine(ex.Message)
Finally
' Release COM Objects.
If Not (objInsight Is Nothing) Then
Marshal.ReleaseComObject(objInsight)
objInsight = Nothing
End If
If Not (objApplication Is Nothing) Then
objApplication.Quit()
Marshal.ReleaseComObject(objApplication)
objApplication = Nothing
End If
End Try
End Sub
End Class
Thank you.
Posted by: Norber
Post date: 9/25/2013 10:01:50 AM
