Problem with SaveAsImage
hello
i have a problem to call the SaveAsImage method.
    if (FAILED(app.GetActiveObject(_T("SolidEdge.Application")))) {
        exit(0);
    DraftDocumentPtr sDoc = app->GetActiveDocument();
    WindowPtr win=sDoc->GetWindows()->Item(1);
    ViewPtr view=win->GetView();  // Here it crashed
It seems that the WindowPtr win is NULL. Do you know how to call it correctly ? Or is there a other way to call the SaveAsImage method of the ViewPtr ?
Solid Edge V19. (v19.00.09.03) and Visual C++ 2005
With nice greetings
Posted by: Heinz Rath
Post date: 10/17/2007 11:11:16 AM
RE: Problem with SaveAsImage
Ah, this one is easy . I've ran into this before.
Draft Windows are different from all other environments in Solid Edge. You'll need to use a SheetWindowPtr.
Let me know how it goes.
Posted by: Jason Newell
Post date: 10/17/2007 11:14:06 AM
