Problem with memory releasing in SE
I'm programming in C# under Solid Edge ST1. I have problem with memory releasing. When I open more parts, or import parts from NX6, and then close all parts, memory still stay allocated and not release. I freeing all .NET wraped COM object via Marshall.ReleaseCOMObject() and try to call GC.Collect() to release unused objects but this not help. When I then open one part, solid edge display Out of memory.
Thanks.
Posted by: Juraj Joob
Post date: 10/1/2010 1:18:22 AM
RE: Problem with memory releasing in SE
We had similar problem and we solve it by restarting SE. I know that it isn't good way, but it works. (Of corse by macro)
Posted by: Jiri Marek
Post date: 10/11/2010 2:52:55 AM
