Problems with EdgeBar c# addin
Hi, all!
I want to add an Edgebar in SolidEdge ST. I use the addin template download from this site.
In .net 2008, I'm not found error, but the Edgebar no show!
Posted by: fat kids
Post date: 6/4/2009 5:46:22 PM
RE: Problems with EdgeBar c# addin
I used the same wizard, with C++ for SolidEdge ST and it works.
Check the registration of the addin in the enviroments, maybe is not registered.
You find documentation in the Addin (Readme.pdf) and also in C:\Program Files\Solid Edge ST\SDK\Samples\Addins\Doc
that maybe can help you understand whats wrong.
Massimo
Posted by: Massimo Magris
Post date: 6/4/2009 8:01:10 PM
thanks Massimo!
I'm trying it.
Posted by: fat kids
Post date: 6/14/2009 10:13:14 PM
