Problems with dimension in a drawing view
When I insert a new dimension (by API) in a drawing view, rappresenting the distance between two elements, the text appears outside the projector lines insteat of between them.
Is there a way to change the text position?
I attached an image to make clear my request.
Thanx
Posted by: Luca Bianchini
Post date: 9/6/2009 11:36:25 PM
RE: Problems with dimension in a drawing view
Hi Luca,
try with:
Dimension.BreakPosition = igDimBreakCenter
Dimension.BreakDistance = 0.5
JR
Posted by: JR
Post date: 9/8/2009 8:01:20 PM
Great!
Thanks a lot... It works!
Post date: 9/10/2009 3:18:25 AM
